I have a 06 float 130X and was wondering if you can lower the travel to 120? The manual stated you can lower it to 100 but the 07 says you can lower in increments of 10mm. Just woindering if I can do the same to a 06? Maybe use 07 spacers? Thanks!
???????Whoaohohohoh said:yes x eleven billion dollars
Thanks Homebrew. Will this also work on a 06 Vanilla?Homebrew said:Yes, just use a 10mm spacer instead of the 30mm spacer for 120mm. You can DIY one as well which works fine.
https://www.sweetspotbikes.com/FoxCustomSpacer/FoxCustomSpacer.html
