1 - 2 of 2 Posts
Basic question, but this is my first time replacing my seals in a fox F29 fit 120 and I want to make sure i get the fluid levels right. I've seen the videos, which basically show draining the oil, seal replacement and the putting fluid back in each side. Then when i go to the fox website i see four fluid levels and not two: damper, damper side oil bath, spring side oil bath, and air chamber. Would i only be replacing the oil baths and the other two are for more extensive service?
MTBR Member
You could just drop the lowers and change the bath oil, when you change the seals. If you want to remove the damper and air spring assembly, you'll need to refill the float fluid on top of the air piston(5ml). The FIT damper is sealed, so you won't need to replace the fluid in that if you don't want to.
1 - 2 of 2 Posts
