Hey guys,
I am having an issue with this fork not releasing from lockout. The remote itself is in perfect condition and working as it should. The issue is that the dial on the crown is not returning anti-clockwise when the cable tension is released. If I reach down and manually turn the dial, it works fine.
I've had the dial mechanism apart and messed with the spring tension but haven't been able to improve the situation. Can you guys make some suggestions on what to try next?
Thank you!
Thank you!
