1 - 6 of 6 Posts
I'm pretty sure the 80's are reduced 100's, they are the same weight. I have a 120 I reduced to 100 by putting the spacer in it. Fox said I could reduce it down to a 80 with two spacers. They only thing you can't do is make the 100 a 120, I think.
I would call Fox to be absolutely sure.
The Other Dude
I just did mine this morning......my F29 80mm is now a F29 100mm fork, it took all of about 15-20 minutes once the fork was off the bike (just easier to collect fluid i thought) very simple and quick if you check out those other posts.
1 - 6 of 6 Posts
