1 - 20 of 28 Posts
I spoke with Fox about whether the new remote lockouts can be used on the recently released 2009 forks and was told "I dont think they will work". They are apparently only compatible with the 26" forks
Does anyone here know if they will work on the F29's? I would think that if the top cap and internals are the same or very similar, it may indeed be compatible.
I just followed up with them and they responded with this:
We currently have all the parts necessary to retro fit a remote lockout kit to our forks. The kit will only work for 80mm & 100mm 29'er forks and would cost approximately $150.0. Please contact us at the number below if you live in the U.S. and would like to order the kit.
I bought the lock out kit through a local Fox dealer and installed it on my F29 RL. It won't work with the RLC version since it replaces the area where the Compresion dial is, among other reasons. I ended up running the right handed remote upside down by my left grip on my SS or 1x9, since it is more natural to me to push the lever up than to reach over it and pull it down. It would interfere with trigger shifters in this set up, but that's not an issue for me.
stlburner said:
Do you know if it is possible to just ditch the compression knob on my RLC and install the lockout, or is there more to it than that?
I'm assuming there's more to it than that, since the compression dial must attach to something in the fork and control it. If you really want the lock out badly enough, I have another Fox F29 RL that I would be willing to trade compression intenals for the F29 RLC damping cartridge. The Fox service site might shed more light on the matter:
http://service.foxracingshox.com/consumers/index.htm
You have to change the Dampener Cartridge to a remote lock out style.
I think this is the dampener that will work, it is from a F120 SERIES FIT REMOTE fork.
820-04-200-KIT Service Set: 2010 32 120 Open Bath Remote Cartridge Assy.
I think this part number comes with the lever & cable also.
This is only my educated best guess, please verify all this with fox before ordering.
I just added the first two of the 3 kits to my other F29 RL:
Kit Part # Kit Description
820-05-054-KIT Kit: 09 32 Remote RL Topcap Assy
820-00-248-KIT Kit: 09 Remote Lockout Lever Assy with Cable Housing and Ferrules
820-00-204-KIT Kit: Cable Holder Assy, 09 Remote RL
The procedure is spelled out under the above mentioned link - quick tech forks - F RL remote. The first kit replaces a few parts in the RL damper, and the second kit is the remote lever. I replaced the third kit with a zip tie around the crown of the fork.
I'm assuming the default compression setting on the RL is equal to the RLC all the way open. The beauty of the remote is that you can run the fork open and plush when you want it, and rigid for sprinting, standing climbing, and fire roads. I use mine for every little uphill since I don't have to let go of the bars to activate it. PM me if you are interested. We could go through the local shop here that I sourced the parts from if that works for you, or we could just do the swap of the cartriges. Either way, it'll be messy and will require an oil change / refill. Just adding the lock out was simple, but swapping the cartridges is more involved.
Fox Remote Lockout
kdiddy said:
Here's what it looks like installed
Kdiddy- been over a year since you posted this- I'm looking to add a lockout remote to two different fox forks- an F29 G2 (same as on your rig, I believe) and on a 2008 F100. Both are RL's. How's the makeshift kit holding up? Does this include some sort of spring release mechanism? I've played with making my own from an old top-mount lever and makeshift parts, but your kit is what I've been looking for- totally frustrated with Fox- they've been telling me for over a year that it is coming for aftermarket "in a few months." It would be a boon for SS's and XC racers all around. I'd love to hear how yours is working and I'm going to try to order those parts today...
My lock out is working fine. The only thing that is make shift is the ziptie on the fork crown, all of the other parts are Fox parts. The part that is on the top of the fork has springs in it, so it pulled thae cable back when the remote is released. These are the Fox part #'s from when I ordered it through a local shop that deals with Fox.
I skipped the last part and just used the zip tie.
I also extended my F29 80 to 100mm at the same time, so i see no reson the F29 100 wouldn't work with the kit. If you are careful, you could install the remote without replacing the fork oil, just don't let the air out of the spring side when you service the damper side, or it will compress the fork and force oil out of the top when doing the service. You obviously have to let the air out if you try to extend or decrease the travel.
Totally wack. I had my LBS contact Fox to order these parts and Fox told them they were discontinued and they're working on a kit with Shimano that should be out in the spring. Ridiculous.
I think the kit that will be released in the spring will be compatible across many forks- as it was before, it was just a replacement of the topcap, a lever/ cable and a cable router thingie for the fork.
I may be putting something together after-market- if it goes to production, I'll let folks know on this forum- probably more in the area of $50-$75 instead of Fox's $150...
1 - 20 of 28 Posts
