1 - 3 of 3 Posts
cgreg said:
When I move the knob to the lockout position... no lockout. Anyone else ever have this problem? Any ideas for a fix?
Apologies if you find my suggestiong insulting, but this would be my train of thought if this was my bike...
1) Sure it's the lockout? lockout is a lever, not a knob on the RLT. (nit picking i know)
2) Sure it's in the lock out position? I believe clockwise all the way to point rearward.
3) shock should still compress slightly with the lockout on.
4) checked your blowoff valve setting? The lockout will blowoff if a big enough hit comes at you, it could be set really soft. Knob on the bottom of the driveside lower.
after that I believe it's time to visit your LBS.
GL,
-don
It could be one of two more things.
1) Lockout lever position on the little hex that the knob sits on. It may need to be moved a few clicks forward.
2) Oil level might be low.
1 - 3 of 3 Posts
