PUSH sells them, I think, and Fox should too. They may want you te send the shock it as the bushing is a press fit. You can fabricate your own tools, to my understanding, the description is burries somewhere on this forum.lemmy999 said:I was wondering how you get the Fox DU bushings that are pressed into both ends of the shock replaced and where you can purchase them. My bike manuf. has shock spacers, but they do not wear, only the DU busings.
You can press them in using a vice, if you can get the old ones out. Not the nicest and best way, but you can certainly do it.MK_ said:PUSH sells them, I think, and Fox should too. They may want you te send the shock it as the bushing is a press fit. You can fabricate your own tools, to my understanding, the description is burries somewhere on this forum.
_MK
