36 Float R model dropped to 140 travel. Post-service I need to drop the forks a good 20psi below my usual for my weight (220lbs) as at the recommended psi the forks react very stifly on the trail. Low psi equals VERY linear travel of course.
Never had an issue of course with the damping and lack of compression control- loved it coming from a lyrik previously however now the forks behave like they really need compression!
Other points to note; all air out the forks fully compress and these are the 09 open bath forks.
Ps. Could it be damper rod is bawked? The rebound control works though.
