1 - 11 of 11 Posts
Is it wise to put a Fox 36 van or talas on a Heckler? Seems like it might be a bit too tall and out of balance with more travel in the front than in the rear. Any pics of one with this fork?
With the TALAS option you can balance out the bike, and have a longer travel fork if you need it.
just got mine friday
im totally blown away by this bike and fork
i went on a 30 mile ride friday
then jumping on saturday
this bike really can do it all
no way
my front wheel never left the ground (except when jumping)
i love this bike
i love this bike
the first pic is short travel
the second is long
i have the talas 36 on my medium heckler. before that i had a 125 rlc. all a round riding i use about 5 inches. on long climbs i put it all the way down. it helps but its not needed. when running full travel i find the steering to be slow. on tight singletrack i understeer then end up oversteering to compensate then have to turn it back. so i like being able to change the travel.
The Heckler can take a 6" fork without messing up the geometry. The longer stroke rear shocks give the Heckler 5.6 inches of rear travel anyways. Not a big difference and you can lower the travel for climbing on most forks as well.
Another 36 Talas here
For long climbs I wind it right down to 110mm, but most other times it's set around 135mm. Seems a good match to the Heckler, nice & adjustable and capable of coping with most types of riding.
Couple of pics for you...
What are you looking at?
no way
i love this bike
i love this bike
the second is long
How do you adjust the travel on the 36? Is it with tools or a nob?
I had almost identical bike (few days ago I've switched the frame to Bullit) and I have some reservations about this whole travel adjustment thing. First thing - upper tubes are not 150mm as Fox claims - it's more like 140-145mm. This problem has been discussed on this forum for many times and until now there is no fix for that.
Another thing is that last 5mm can't be used (bottoming), so travel is being reduced to 135-140mm :-(. And last thing- I never managed to reduce travel for more than 115 mm. Summary ? I spent aprox. $1000 for the fork that has 140mm travel instead of 150 and it reduces travel to 115mm which gives 25mm instead of 40mm. Let's say I'm realy disappoined. My advice - take Fox 36Van if You want Your heckler for some FR stuff or just get Pike, Vanilla or some Marzocchi with it's weight penalty but forget about 36 TALAS. It's not bad - it's simply not worth.
Regards,
serhij
I'v got a 05 Heckler, and a freind lentme his 36 TAKAS for a week. This combo rocks! The fork is light, stiff, adjustable, and suits the Heckler fine. I'm definatley considering this fork for next season.
The bike can be balanced perfectly for both climbs or decents, with the travel adjuster.
Love my Heckler
1 - 11 of 11 Posts
