Hi. I have recently done a major bike upgrade from something with RockShox Rebas to Fox 36 Grips 2. Although the Fox 36 is clearly better, they just don't quite feel as good as I imagined such a high upgrade would feel. They don't feel quite as plush as I thought they would.
I recently bought a ShockWiz and in doing the calibration (which requires you to remove air and fully compress the forks, then full extend them multiple times), I got in a situation where I needed all my strength with my foot in between spokes, to fully extend the forks.
I can only imagine that the air is not transferring between the positive and negative chambers. Does this sound right? I'm guessing there is too much grease in the air chamber blocking the port between the 2 chambers. If this is the case, would this also explain the lack of plushness? Also, I've noticed that the forks do not fully extend when setup with the correct pressure - they are maybe 3mm to 6mm compressed just sitting there.
I'm happy to do a lower leg removal myself, but I don't have any of the (2 different) fluids and suitable grease yet, so just wanted opinions before spending more. :thumbsup:
