I have been running a 36 float RC2 spaced at 150mm for the last couple of months and so far I'm not really blown away by its performance. I came from a Pike 454 and while its stiffer than the Pike I cannot get it tuned to be as active. It seems like the small bump compliance is horrible.
Here is how I have tried to tune it so far. About 220 rider weight with gear.
70 psi 8 clicks on rebound and 2 clicks on high and low speed compression. Sucked... the fork was too stiff and bounced too much.
60 psi 5 clicks from full rebound. 3 clicks on high and low speed compression. Performance is a little better but still not great in the active dept.
About 58 psi 5 clicks from full rebound. Had to raise the high and low compression to 5 clicks to help avoid dive. This made the fork more plush but it started to feel sloppy.
I'm pretty much at my wits end with this float so I'm hoping you guys can offer some suggestions. Are fox 36's just not that active of a fork? Maybe I should just move to a lyrik.
Thoughts?
Thoughts?
