1 - 9 of 9 Posts
Hey. Imma do my first fork service.(fox34 performance elite fit4) Im planning to do a lower service. Fox recommends changing the 3cc oil in the air chamber. When is this step taking place? Is it a step of the lower leg service? I dont find a single video about it. Not even a discussion. Do i really need to change it? If yes, how often and how.
Thanks for the help!
The only way to "change" the 3cc of oil in the air chamber is to pull the air spring out.
The 3cc on top of the air spring will eventually migrate through the equalisation dimple into the negative chamber.
If you just add 3cc each time without cleaning the air spring you will just be taking up air volume.
Discussion Starter · #3 ·
Then i guess i should just leave it as it is. Im not riding way too much. Should i just leave it for the bigger service/ rebuild?
And now only do the lower leg?
1 - 9 of 9 Posts
