Regarding the open mode 22 adjustment settings compared to the on the fly lever. Is the lever adjustment in medium mode equivalent to any of the 22 settings in open mode?
Are you referring to the FIT4 damper? If so, then no.Regarding the open mode 22 adjustment settings compared to the on the fly lever. Is the lever adjustment in medium mode equivalent to any of the 22 settings in open mode?
It may feel the same in certain situations but it will likely not be a direct one to one. As a side note, check out this text from the vorsprung fractive installation manual for the fox 34/36 with fit 4. https://cdn.shopify.com/s/files/1/0..._Fit4_Damper_Systems_3.pdf?131374290201626989Regarding the open mode 22 adjustment settings compared to the on the fly lever. Is the lever adjustment in medium mode equivalent to any of the 22 settings in open mode?
"1. The stock Fox LSC adjuster (not replaced with this system) is quite ineffective beyond approximately 12 clicks out from fully closed/firm. Although it has approx 22 clicks total, the 10 softest of these make little difference, so your realistic range is between 1-12 clicks from fully closed. We don't generally recommend running the adjuster fully closed - if you need to do that, you should either consider using a firmer HSC setting or installing a firmer valving. Likewise, if 12 clicks out is still too firm, use a softer HSC setting or a softer valving."
What?So the dial will exceed the firmness of the lever in the middle setting?
Vorsprung LuftkappeOn the subject of the Fox 34 and LSC...
Mine has the Fit 4 damper and I'm pretty sure I have the air pressure dialed. I'm ~180 lbs. ready to ride and I'm running it at 60psi in Open mode with 16 clicks of LSC. How would I go about reducing the amount of brake dive I'm getting on relatively flat, twisty, pedally trails without making the fork feel harsh and giving up small bump compliance? I feel like it is already a borderline performer in those situations.
Thanks.
Given the PSI you are running, it's probably way over-damped, like mine was, this puts you in between a rock and a hard-place. Vorsprung Fractive if it's a non-SC model, or Push tune if it's not. I'm more like 165-170 running more like 80psi now, now that the damping has been reduced. All is not perfect, it still feels like the HSC and HSR are pretty heavy, but significantly better than before, as evidenced that I can run higher PSI with less spacers. That is when you know you are getting decent support (not diving excessively). Like you, I was having to run around 55psi and a bunch of spacers to get any compliance, because it was just way too overdamped. The real kicker was that my 32 SC (used on the same bike for races) felt better than the 34 SC that had more travel. That's finally changed with the tune, but that's how crappy the factory tune was.On the subject of the Fox 34 and LSC...
Thanks.
I run 90 on mine (34/130), with around -10LSC from closed. IT's sharp on flat trails, but performs the best in a high speed DH situation. I weigh around 205#. Just accept that it will feel, almost, locked out on casual trails.[/QUOT
Do you achieve full travel?
That setup sounds about as useful to me as running a rigid fork.IT's sharp on flat trails, but performs the best in a high speed DH situation. I weigh around 205#. Just accept that it will feel, almost, locked out on casual trails.
Pretty close. Try to get as close as possible. If you're running too soft to get that last 5mm of travel, then it's not worth it.Do you achieve full travel?
Until you run white knuckled, off a drop into a G out. It recovers and supports you at speeds that a comfortable setup won't.That setup sounds about as useful to me as running a rigid fork.
Unfortunately there is no such thing on the trails where I ride. But hopefully your suggestion can be of assistance to someone else reading this thread.Until you run white knuckled, off a drop into a G out.
