I'm looking to up the travel on my 2016 fit 4 fork the years with the more lighter gold stanchions. Currently it's set at 120mm and I'm looking to go to 140mm as im wanting to use it for some bigger terrain when im not on my big bike.
I believe I've found the correct air shaft which is difficult to source as well but I've heard conflicting things that some 120mm can go up to 150mm but some versions cannot as in there is not more stanchion in the lowers. This was an OEM fork for the 2016 kona explosifs. Trying to avoid pulling the lowers to check if it's possible then pulling them again when the spring gets here. Included the best pic I have of the fork if that helps anyone
Sent from my SM-G970U using Tapatalk
