1 - 20 of 107 Posts
aka bOb
Thanks, hadn't seen the frontal pic :D Looks like 65mm rims with floaters? I believe this could be a good viable option.
This fork has the wheels turning in my head. What about setting up the front end of a fat bike like the Surly Wednesday with the Fox 34+ fork and 27.5 x 3 tire on a 45mm rim up front? Pair it with a 26 x 3.8 or 4.0 out back on a 65mm rim.
With this combo you could get the majority of float from the back and more precise steering up front... It may even work better than 26x3.8 on packed snow.
aka bOb
:skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep::skep:
nuff said!!
Is dang happy!
I wonder if the 2016 Rockshox Pike 27.5+ can pull that off?
The Bluto is just too noodley! 2017 is a long time to wait for a Fat Pike!
nuff said!!
I was thinking one of the larger 27.5+ tires like the Bridger...but yeah, nuff said.
This is why I put a 2015 Lefty on my Pugsley. It will be great as a "firm snow" bike. It is wide enough to run a B+ tire up front and whatever I want for the rear. Love the idea of a Wednesday and the Fox fork.
Discussion Starter #20
The fact it will fit a 4" tire on a 65mm rim is sweet - I'd pick one up if I could make my I9 135/142 front hub work with the new boost front standard. Just got it laced up to a LB carbon rim. Maybe someone out there could make some adapters. Without having done any measurements, I'm doubting that it would work without at least some re-dishing of the wheel. I also wonder if the Manitou + forks would have similar clearance?
1 - 20 of 107 Posts
