Hello,
I am going to remove the lower legs from my forks so that I can give everything a good clean, just wanted to ask a few questions so I hopefully wont run into any problems. I have all the required tools but just need to make sure I have the other essentials.
So far I have some Fox Float Fluid which I will use to lube the seals, will I need to also purchase some 10wt shock oil? Can I remove the lower legs without loosing the shock oil? I only have around 10 hours use of the shocks so assume the oil should be fine, just want to keep everything clean so they last as long as possible.
Do I need to replace the shock oil as good practice? if so what would be a decent choice of shock oil? can I just use a good quality 10wt motorcycle fork oil?
Any advice much appreciated :thumbsup:
