rooster44 said:
I should have been more specific. I'm building up a new Ti 29er & the fork that seems to be the best option is the Fox. I see the 100mm comes with the thru axle option but my DT Swiss 240 Hub is the older 9mm version. What I want to know is if the advantages of the thru axle outweigh (No pun intended) going with the lighter 9mm & not having to replace (or modify) my existing hub...Seems like the future of forks is this thru-axle but is it just marketing or a true meaningful & beneficial innovation?
lighter is irrelevant - its too negligible to be a factor though your 240 hubs are really light, so there is that
however, and more important, is how much do you weigh? how much money do you have to burn (for new hub/wheel assuming your 240 cannot convert to 15mm or 20mm)? what type of riding will Ti 29er be for?
I honestly dont know much about the DT line of hubs (in terms of being able to convert to other axle configurations) but certainly, if you plan to do XC riding and you are not a phat ass and I assume your new Ti 29er (hardtail i assume?) will be for XC type purposes, or even more, assuming you dont plan to get too aggro and dont weigh too much, something like the DT RWS skewer will be MORE than enough. It may VERY well be that putting money into a whole new wheel is a total waste of money
Stiffer is perhaps a real thing with the 15mm or better yet 20mm thru axles BUT, and a big butt, it may not translate into anything meaningful on the trail which is what i think you are asking. again, that depends on your weight, riding style, etc
