Having some problems with the lockout on my Lapierre X-CONTROL 310 L 2010. Forks are Fox 120mm travel 32FRL open bath. Just can't get the lockout to work!
I've just tried an oil change in case it was a low level problem; not sure what came out as I managed to spill most of it! Anyway I put 165ml back in, assembled the valve, cycled the cylinder a few times, put the air back in. Still no lockout.
BTW I used 5-30 synthetic for the time being, wondering now though if perhaps oil viscosity may be an issue, 10wt green I think is the recommendation.
The lockout valve gets screwed into the bottom, then you add the lock lever in the locked position I presume. Anyway, I backed it off a little as well, still no joy.
Gotta be a simple fix here, but just can't see what's wrong.
Any ideas please?
Any ideas please?
