I have a '98 z1 on my hardtail with 100mm that should slowly be updated. After seeing that one leg of the 05 All Mountain is air and that the z1 is only 20mm dropout, I think I need to bite the bullet and get an 04 something which is the reason for my question:
Is it possible to bring an 04 z1 down to 100mm of travel? I know that with the 99-00 z1s you could change the travel by using a shorter positive spring and a longer negative spring. I would really like the stiffness of the 32mm stanchions but don't want to risk running a 130mm fork on my hardtail.
