Looks like the transition needs a little cleaning up
Yes you'll be suprised at how much just unweighting the front'll get you... This type of endo still gets me on new terrain, it's decieving from up top how steep it can get!LeeL said:ouch - might i suggest pulling up and landing it both wheels first? Entertaining though no doubt
Yes! Yes you can, and you should! Dude, that was hilarious! But I know you can clean that. You know where the dip is at the bottom by now... pull back and pedal through next time, you'll make it.Cobretti said:I don't know if I can unweight the front while skidding down a steep slippery rock.![]()
I agree Bro... You can hit that! Right before you come to that ridge before the dip let of the back brake, weight back, give a little lift to the front and roll it. Try not to use you back brakes, If it gets dicey then use then front.... trust your front brake, it can handle alot on a section like that especially if your weight is back.BunnV said:Yes! Yes you can, and you should! Dude, that was hilarious! But I know you can clean that. You know where the dip is at the bottom by now... pull back and pedal through next time, you'll make it.
