1 - 20 of 20 Posts
'All over it!'
The Avid sets are kit 108 & 109 and will not work with Formula as far as I know. I have just purchased goodridge hoses for my formula brakes and ordered kit 101.
If it's just the connector kits you are interested in, then you would require connector kit 101.
If you look at the connectors for both formula and avid, you will see that they differ as formula use the banjo connector. Maybe somebody else could add more or even correct me If I am talking bollocks.....Hope this helps
Feeding your addiction
  • Like
Reactions: LyNx
Ventanarama said:
ONE's use the #109 kit, Oro series uses 107/101.
Larry
Mountain High Cyclery
[email protected]
Thanks for that.Are you definetely sure they are? I have been looking at what kits i need for my ones and the kit i found pictured didnt look right for the lever end.
Would the front and rear kit be the same but with different length hoses?
I ordered the 109 kit for the formula the ones awhile back but ended up sending it back as after much head scratching and an email or two to the goodridge supplier I found you still need to use the original formula fittings for the lever end and the formula olive was proving to be a pain in the a*s to fit over the goodridge hose and I wasn't convinced on how good a seal would be made.
Things may have changed since as it was a little while ago, but if your gonna do it, you'd be better off just ordering up one of the fitting kits for the oro as I'm fairly sure this will give you the two banjos you'll need for both calipers.
hope this helps.
cheers
hope this helps.
cheers
Hmmm, what part of the lever end fittings was not working for you? I've installed #109 kits on ONE's with no problems. The #107/101 kit for Oro's won't work on the ONE as the thread pitch on the lever body is different.
Larry
[email protected]
Yes, Larry is right...I have the 109 kit on my One's. You don't use the Formula olive with Goodridge lines, just screw the male fitting into the lever and attach the line with the female fitting and tighten them up.
Larry did you get any of the R1`s in?
Haven't seen any R1's available yet, hopefully soon though.
Larry
Larry
[email protected]
Hi Larry, it's quite possible I was supplied with the wrong parts then as the kit I recieved didn't have any parts for the lever end other than the threaded collars that screw into the lever body, there was no insert for the hose or anything, after a few emails to the suppliers I was told I need to use the formula lever parts, maybe I'll order some up from elsewhere and have another go.
cheers
Did You get this set:
Do I have the correct lever-end connector? Seems to be coarse pitch thread.
The reason I'm asking is because I previously ordered the same 109 kit from CRC and got diffferent lever end connector (fine pitch lever end) as seen here:
One thing to look out for is that there are pre 2005 Juicy 109 kits and 2005+ Juicy 109 kits.
From looking at the threads on the lever body fitting, I'd say the pre 2005 kits are the right ones for The Ones. 2005+ Juicy's have a finer thread on that fitting.
Right?
Edit: It seems that there may be some mis-labeling in Goodridge land. I have a kit that says 'MTB109-1FCB-BK" on it and "Avid Juicy 5/Juicy 7 (2005)"….the kit for 2005 Juicy's with the fine pitch thread are supposed to be MTB110s.
109 kit on Formula RX
Hey,
This thread is a bit old, but I'll resurrect it for lack of info on this 109 kit otherwise.
I've transferred my Goodridge lines from Hopes to the Formla RXs using the pictured 109 kit from CRC. Things have gone pretty well, until I slid the longer tapered end down into the lever reservoir. There is NO o-ring that's meant to go on there as I can tell, and it's weirding me out. It fits snug, and everything's tightened up nicely.
I'll be testing it out tonight, but just wanted to hear back about whether this is meant to be attached to the lever with no o-ring in sight.
Thanks,
Mike
3D guy
I have to really tighten my lever end (tighter than I thought I should to prevent leaks). That was last year and no leaks and no problems. Also be very careful getting the cylinder to screw on to the end of the hose (e.g., do not mess up the cone end it is required to seat well).
Legend
I have e-mailed Goodridge a few times over the last few weeks as I find differing info on the Internet. From what most people say, my "The Ones" require the 109 kit, but Goodridge has told me 101 twice, and 109 once. This thread is pretty old, and I heard that Formula possible changed the thread pitch at some point which might be confusing things. This is exacerbated by the fact that I bought The Ones as old NIB stock (so I am not sure what year I even have).
I worry I am going to buy the wrong kit, as my luck is horrendous with these things and a mistake is pretty pricey (and time consuming). I should probably just pull my lines and see if I have fine or coarse threads ... would probably get me pretty close to a definitive answer..
Here's some more info from Karl ( [email protected] ) :
Thanks Karl for taking time to answer these questions. One last one! The threaded collar that holds that flared fitting into the lever is pretty long, and there are several threads exposed. The other side is even a bit longer. Any issues?
Mike
Mike,
Shouldn't be a problem.
Karl
I think I'll answer my own recent thread and put together a Formula RX and Goodridge lines list of facts http://forums.mtbr.com/showthread.php?t=700840 Thanks for everyone's help so far.
1 - 20 of 20 Posts
