I have a new pair of Formula Cura 4 brakes and after shortening the hose and doing a bleed I noticed mineral oil (cadence is a drip, drip, drip and not a blast or jet) coming out of the silver circle in the photo below (courtesy of https://nsmb.com/articles/formula-cura-brakes-teardown/)
This only happens if I pushed or pulled mineral oil up from the caliper at a certain pressure (not hulk smash pressure but from time to time) and also when i pushed the pistons in the caliper back to seat the pads to center the caliper.
I have had Shimano Zee and several sets of Magura brakes and since this is my first Formula set I'm not sure if this is normal/expected or not.
The silver disk has a hole in it so I would assume that this is going to be the case to keep some idiot like me from blowing the master cylinder seal.
Any Formula gurus that can weigh in on this?
