Best brakes that I have ever ridden
Rob,
I'm riding the K24's. They are the best value in the line imo. The pad adjustment switch works much better than a Juicy seven and it has the advantage that it will not get knocked off. You can adjust the pad contact feel while your riding. In the real world, once you have it set you don't need to touch it again. I saw the Oro puros on sale for $215 online (Jenson?). But if you can get some K24's the performance is the same and it adds one ounce of weight.
I'm riding the front at 180 mm and the rear at 160 mm. The power is true one finger. Kind of like one hit (you know what!), it is the real McCoy of braking. They are squeakless and unlike the Juicy's you don't need to buy aftermarket rotors and pads to make them work. I don't like the lever feel on the Marta's return spring. The Hayes levers rattle like cheese and the modulation is suspect according to reports.
Enjoy!
Cheers,
Kane
Rob,
Enjoy!
Cheers,
Kane
