My 2¢...
tommydfatguy said:
I just purchased a Giant NRS 2 which came equipped with a Skareb Elite. The Skareb wouldn't be a bad fork if I were 150 but I weigh about 225 on a good day. The fork bottoms out easily even at max PSI and its pretty spongy on the sprints/climbs. I'm wondering if anyone has any recommendations for a good moderately priced fork that does well with heavier guys. I like the Marzocchi lineup - has any heavier guys tried any of these forks?
Stay away from Fox forks. I don't feel they're designed for larger riders and while many smaller riders rave about their suppleness and stiffness, larger riders (who tend to mash vs. spin) tend to blow through that suppleness and your shock becomes an expensive pogo stick.
That said, I'm a big fan of air forks vs. springs. I've found air forks more adjustable and you can stiffen higher end almost to the point of no bobbing without affecting travel and bigger hit compliance.
I ran a higher end Sid for several years and while extremely flexy through corners, held up well as an air shock.
I've run a Marzocchi Z1 in the past and likely it quite a bit, but it wasn't the right type of fork for me. It again was too bouncy. It performed exactly as it was supposed to on drops, though. I have no complaints.
I'm currently running a Marzocchi Marathon SL. I really like this air fork because I can dial in the shock stiff enough for me to stand up and mash, but it is also supple on drops. It's fairly stiff. Not nearly as stiff as the Z1, not as stiff as the Fox Talus but significantly stiffer than a Sid. I haven't ridden your fork, so I can't compare the Marathon's stiffnness to yours.
Keep in mind, the "best" of any bike component is subjective. What works best for me may not work best for you.
My stats:
Riding: 10 years
Weight: 215 pounds
Riding style: Pushing bigger gears vs. spinning
I enjoy the climbing only because climbing eventually leads to pointing the bike downhill.
I currently have two bikes:
Retrotec Singlespeed
Turner 5-Spot
I like them both, but I prefer the SS at the moment.
Hope this helps.
Ken
