1 - 16 of 16 Posts
Dekerf SS...Ridley...Tantrum... Growler...Marino
Hey El Rey riders! I have been ridding my 08 with a 07 100mm Reba fork and I think it handels quite quick already. My question is how would the bike ride with a different fork offset like a newer fox or even the newer reba. Most of my riding is on tight east coast singletrack, with limited long climbs and decents. When I first built up the bike I had a 100/-5 stem and a flat bar....and well I went over that bar a few times! I now have a 90/0 with a low rise bar and is all well with climbing and decending....so any input about what you guys are riding with up front would be great!! Thanks!
dreamer
I ride a 17, and use a 08 Fox w/100mm, a 90 low rise stem, and super wide DH bars, they slow up the front a bit, as I am very fast going up, but the El Rey will climb anything, it helps when the climbs get sketch. Thats just me, hope it helps.
Slow and steady
Had an '07 Reba 100mm on my '07 El Rey until recently. I just put a 120mm Air UTurn '09 Reba on it. The handling at 110mm feels about the same as the old Reba at 100mm. When extended all the way out it suffers a bit on the climbs due to being a touch too slack. When set to 90mm it is kinda twitchy for my taste. I pretty much have left it at 110mm all the time unless I'm going up or down something super steep.
Discussion Starter · #5 ·
Thanks 1red1 and Tony! I feel fine on the climbs with my set up now, it's just downhill stability thatsomewhat eludes me. I may try to put on the smaller extended crownrace to see if that helps or hurts. Thanks again, RRR
Wb110
sure was a improvement over the reba in terms of stiffness and travel
Expert Crasher
JRM - I've got a Fluid 110 on my Sultan. Been playing with air pressure today - last trip out, I was 80 psi, none on the right leg. Today - I ran 70 psi w/ about 7-8 psi in the right leg - felt very smooth, had a nice progressive feel. 210lbs body weight.
Just wonder what you're running, any tips/setup you can offer. I've had my fork since September.
Eric at WB suggested I try running half my body weight in the air spring and zero PSI in the compression. I found this to be very smooth and have not noticed any harsh bottoming. I have a F110 on an El Rey.
I saw that..
Getting the psi in the right leg correct is the tricky part. I think i ran about 8-10 psi so that i could balance the rp23 compression set 1/2 way out. I found that if i ran more then 12 psi the fork started topped out
Expert Crasher
thanks - PUSH tuned RP23 on my Sultan. I think I've got about 7 psi in my right leg.
TRB - thanks as well - I'll have to give that a shot too.
Sorry to derail - back to Ventana's :D
I'm running a 70mm stem, with 28" wide bars and a little extra air psi in the fork. I found this helps the steep descent handling without hurting overall handling. I to had a trip over the bars followed by a trip to the hospital.
1 - 16 of 16 Posts
