1 - 2 of 2 Posts
· Registered
2017 Fox Rhythm 34 started life @ 130mm and I dropped to 110mm when new. Decided to try a DSD Runt but was told minimum 120mm for proper functionality. Assembled w/ 120mm air shaft & DSD Runt. Inflated to recommended 2:1 pressures and the fork felt really firm - no sag. Hit the trails and ended up running a lot less pressure and still firm. Removed the Runt and went back to OE air cap & original pressures - still firm.
I have noticed I can compress the fork then hold the wheel down and pull up on the bars and extend the fork 7mm. Also w/ the air cap off if I compress the fork it returns up about 3/4 of the way. Air in lowers? Thanks.
1 - 2 of 2 Posts
