I've heard the Rock Shox Tora 318 is a pretty solid fork. It's a little above your budget at $249 on Jensonusa.com, so you might be able to find it cheaper someplace else.
Yeah, that Recon looks like a decent deal - It's basically the same as the Tora 318 with a few minor differences; Stanchions - Tora-Chromed steel vs. Recon Ano Alum., and Steerer tube - Tora 4130 steel vs. STKM steel, and the Recon is claimed 2.27oz lighter.Ktse said:If tora, why not recon?
http://www.jensonusa.com/store/product/FK289A01-Rockshox+Recon+351+Coil+U+Turn+Frk+08+Oe.aspx\
My buddy got one of these. Good fork when it worked, unfortunately it needs to be warrantied as the motion control damper started to leak into the lowers.
so if the headtube on my rincon is 4.6 inches, I'm good right? What about the 5.7 on the other frame I'm considering building up?highdelll said:Yeah, that Recon looks like a decent deal - It's basically the same as the Tora 318 with a few minor differences; Stanchions - Tora-Chromed steel vs. Recon Ano Alum., and Steerer tube - Tora 4130 steel vs. STKM steel, and the Recon is claimed 2.27oz lighter.
Personally, I like the 'toughness' of the chromed steel stanchions over the ano alum., but W/E.
Just know that it's an OE take-off, so the steerer has been cut (185mm) - So measure your headtube and your total stack height (Headset, stem - usually 40mm, and any spacers you plan to use)
OK we know that the Jenson OE Recon has a 185mm steerer..laxman2001 said:so if the headtube on my rincon is 4.6 inches, I'm good right? What about the 5.7 on the other frame I'm considering building up?
Well, I guess that's a whole different ball of waxlaxman2001 said:Well, I'd get separate forks for each frame, but you like the coil over the soloair? All I know is that my XCM is a P.O.S. and that I love my f120r.
