Has anyone here seen plans for an inexpensive fork stiffness meter?
I use a 2004-5 110mm Drop-off Comp with quick release drop outs a lot. To make it stiffer I use a Skraxle (or an XT-skewer so tight it is not quick to release). But even still, there are disconcerting instances during rocky descents where the relationship between the bars and the direction the wheel is pointing is not what it should be.
In the interest of quantifying the benefits of 20mm drop outs I am building a fork stiffness meter consisting of a laser level that mounts as a stem cap. The idea is 1) put the rim in a well, 2) pull on the bars with a fishscale, 3) use the laser scribe line to make sure the bike is verticle, 4) use the laser scribe line to determine the amount of twist.
Budget is $50.
Please reply if you have ever tried something like this and can make things a bit more effficient (by providing detailed plans?).
Budget is $50.
