Hello,
I am hoping that some of you super-wise suspension people can share some thoughts here - to help me setup my suspension properly.
Bike = 2018 Hightower
Fork = 150mm Lyrik Ultimate
Shock = 135 DPS EVOL
I am trying to get things dialed in using a Shockwiz, and it would appear that I have somethings dialed and it's impossible to dial in the others. On both of my bikes - I get SAG and Tokens good, and then the system tells me I need to make compression settings softer. The problem is that they are at their max. soft setting. I am wondering how air pressure and tokens effect the compression settings, as I am a larger rider.
What I'm finding is that if I use more tokens - I leave too much travel left after a ride. But, if I don't use tokens - I will max. out the air pressure settings and get a pogo effect (more so in the rear), particularly when climbing... which feels like it's robbing energy on the climb.
Some base line starting thoughts would be most helpful here.
Thanks,
-A-
Thanks,
-A-
