1 - 2 of 2 Posts
Does any one knows if it possible / recommended to change the ROCKSHOX REBA
travel , I think it is originally set to 85 , but it may be changed to 100 or 115.
No the Trance is a 4"/100mm suspension bike and as such the REBA comes set to the 100mm travel setting. Yes it is possible to change the height of all REBAs, there are internal spacers that you either add or remove (requires you to take the fork apart) or if you have the U-turn version it's adjustable externally. When it comes times to change/service my REBA (I'm actually at the 50+ hour mark and according to RS should change the oil in) I'm thinking of chaing it to the 115mm setting.
1 - 2 of 2 Posts
