So, I serviced the lowers of my Rockshox SID yesterday. Suspension servicing is one of the only pieces of bike maintenance that I had been outsourcing to bike shops, due to not wanting to deal with a bunch of oil in my living room, which is the only place that I have to work on my bikes.
Anyway, I decided to give it a try and it was a bigger disaster than I had anticipated. It took many many tries of threading, unthreading, and striking the lower bolts to get the shafts loose enough to get the lowers off. I ended up having to take the fork out of the stand to flip it upside down to get a good hit, which got oil everywhere.
Finally, when it came time to inject oil into the lowers, the syringe got stuck (think the plunger end couldn't handle the oil weight) and the piece of extension tubing that came with the syringe was too big to fit into the bolt holes, so a lot of the oil didn't make it in.
I decided to do a search on this forum to see what people were using for syringes and where they were getting them, and I learned that I could get a Mixmizer at Walmart. As it turned out, the syringe worked well with the oil, but the tubing that it came with was still too big.
Anyway, the bold holes on the SID sit deeper into the lowers than they do on a lot of other forks. So, I'm curious, what kind of extender tips or what people are using to get oil into forks with that design?
