you`ll be fine. The other thing that you must look on the package is that it doesn`t say anything about seals swelling (please someone correct me if I spell this word bad...wich I think I didhamba said:Does anyone use Maxima Fork Oil 7wt for Fox Vanilla 125RLC? I only found this type of oil in my area. Is it good? Any review may be help. Thanks.
it's good. slightly more fluid than stock oil. compression damping will decrease and rebound speed will increase. not a huge change but noticeable. you'll love it if you don't weight too much.hamba said:Does anyone use Maxima Fork Oil 7wt for Fox Vanilla 125RLC? I only found this type of oil in my area. Is it good? Any review may be help. Thanks.
i'm 140lbs too. buy maxima 7wt , it' s the right choice for your weight.hamba said:30x26,
If I am about 137lbs, should I use 7wt or 10 wt?
that you only put 140cc of oil in the damper side?30x26 said:i'm 140lbs too. buy maxima 7wt , it' s the right choice for your weight.
more ideas: http://forums.mtbr.com/showpost.php?p=1764625&postcount=5
maxima 7wt and less oil (suggested volume minus 10cc) give a noticeable improvement for light riders who don't jump too much
yes 140cc, obviously only if you don't get full travel. oil height lower than stock does't damage the fork , it only gives a more linear compression.fran said:that you only put 140cc of oil in the damper side?
Is that good for an open oil bath fork? I `ve read that this kind of dampening systems are very sensitive to improper oil amounts...
