Hello
Basing on this http://g-tedproductions.blogspot.com/2007/01/revisiting-trail-and-head-angle-for.html
and
http://www.kreuzotter.de/deutsch/lenk.htm
We are able to calculate ground contact patch for a given fork offset and wheels size.
Let us see the steeper the HA is and the more offset we have the smaller the contact patch is.
The slacker the HA and less offset we have the more contact patch we get.
The steeper the HA is the less offset we need to get the same contact patch with slacker HA and longer offset.
Thus slack angles + long offset will improve the handling - less contact patch, but longer wheel base - the whole bicycle is long and unpractical in tight switchbacks.
Until now everything is intuitive and common. Here comes an example of Spider 29" which is reported with 73' HA (or any other 29" bike in the future) to be ready to pitch you over the bars more likely than other with slacker HA. Of course we get the steereability of 26er, but DH section must be tackled with your butt going farther behind the saddle.
- My question is what would happen with Spider 29" DH inappropriateness if we get Reba with 43mm or 51mm offset instead of 38mm. Will that much offset make it harder to endo on DH sections or the bike will get too twichy and will be swayed from side to side like 26er on uphills (the front wheel fiddling)
If we got Reba with 35, 32, 30mm offset, accordingly this would make more contact patch but how would it affect DH section on our mentioned Spider 29"?
and
