1 - 7 of 7 Posts
I suppose your frame is build for a 80mm travel fork, when mounting a longer travel fork you'll slacken the headtube, which will result in a more sluggish handling bike.
Your headtube (and thus your handlebar) will be higher and you have to slide your saddle forward on your seatpost, which will give you a shorter effective toptube .......
If you can live with all this, give it a try!
In FTF We Trust
I had a Diesel SS that was built around a 80mm fork and I rode it with a 80 mm Psylo for a while, but later switched the travel to 100mm and like the way the bike handled a lot more. I wound up selling the frame and fork together because the wheels were too small (I got hooked on 29ers) but it was a sweet handling bike with the 100mm fork. The rule of thumb is that for every 1" you add to the fork length you steepen the angles by 1 degree.
1 - 7 of 7 Posts
