What kind of brakes? Cantis? Is the cable stop in the headset stack or stem?
-Joel
-Joel
Sorry, critical info missing... 203mm Avid disc. Continuous housing, run to a clip on the front of the left fork leg and then up to the lever with a bit of slack to spare.Clockwork Bikes said:What kind of brakes? Cantis? Is the cable stop in the headset stack or stem?
-Joel
Yep that's too light a fork for a 250lb. rider. A fork like that would be fine up to about 190-200 I would think. Had it been designed for a thru-axle that would help a bit, maybe. You're just asking the fork to work too much particularly with a 203 rotor, maybe try a 180.rocwandrer said:This is with 1.25" x 0.035" x 16.75" long "rigid" fork blades and a 250 lb rider. A 160 lb rider can not reproduce the problem.
thoughts? suggestions?
Here is your chance to correct the offset with a new beefier fork.rocwandrer said:Mild braking==> ok
Very hard braking on a steep downhill ==> ok
Moderate braking ===> chatter, no perceived brake steer, but very disconcerting stuttering. Fork can be observed flexing forward and back in phase with the felt and heard chatter.
Richard
yup. I was just a little gun shy to jump to that conclusion after being convinced, but having it wrong on the handling issue which really everybody with this tire and rim combo has (and bonus, isn't an issue at all on snow, even on hard packed/icy).shiggy said:Here is your chance to correct the offset with a new beefier fork.
