1 - 3 of 3 Posts
Hi,
I have ordered 2011 Sultan (large size if it matters), and now I'm trying to get some decent headset for the frame. I'll be using Marzocchi 44 RC3 Ti 29" with straight 1-1/8 steerer so my first choice is inset (semi integrated) headset both top and bottom cup. Since most of you is using TR44/52 bottom cup I started to worry about clearance between fork cups and a down tube. Do you have any reports in this matter ?
I've found one pic of 5-spot in similar setup, but that's totally different frame...
Thanks, serhij
Discussion Starter · #3 ·
Thanks, that makes things clear - Reba is wider than 44 (110x20mm axle vs 100x15mm), crown and cups have similar shape, so 44 should pass under without any problems... Thanks again.
serhij
1 - 3 of 3 Posts
