Still too much snow where you’re at? Otherwise, I can’t imagine being able to resist getting it out where it belongs.
It's still very wet at altitude but mostly, I have been under siege following a recent "promotion". I will be putting it through its paces this weekend.
On pavement the bar feels a little narrow (it's uncut at 800 mm), the fork feels a little floppy (it's a 36 at the spec'ed 44 offset), the cockpit feels a little short, and the bar feels a little low. All first world problems that I will tweak if I don't get used to it all.
All that said, this is going to be the nicest bike I have ever owned. I know that already. I can very distinctly feel the benefit of the rearward axle path hitting curbs at speed.
I am a former owner of another of Owen Pemberton's creations - a 2015 Range, which also purportedly had a rearward axle path. Between the 2 bikes, there is no comparison. None. The Druid truly is going to be next level, once I get it in its element.
EDIT: I tweaked the saddle tilt and dropper height which pretty much addressed all the cockpit issues mentioned above. On to suspension fiddling now... Setting sag is not as easy as on other bikes because the shock stanchion is somewhat buried in the frame.
EDIT: There is no additional driveline drag that I detect from the idler pulley and chain guides. If there is, it is pretty much immaterial.
EDIT: Standover is awesome and for whatever reason, I can do a track stand longer on this bike than any other bike I have or have had. Track stands are effortless. I suspect a low center of gravity may be assisting in this regard.
