I took it out for a couple of hours yesterday and then handed it off to a workmate who's 2 bikes are down right now. He instructs MTB at Whistler over the summer so I look forward to his take.
A little about me. 60 years old, live for the descents, ride 4 days a week, not afraid to climb, intermediate skills and lots of times in the top 10% on black descending trails ( some of these on a HT) My personal bikes are a Pipedream Moxie and a Knolly Fugitive.
The Druid. We set the sag at the shop, I checked the tire pressure and swapped the brake to right front. I left the 50mm stem and 20mm rise bar. Ideally I would run a 40mm stem and flat or 10mm rise bar an this bike. I was a bit too upright. I should have taken the time to swap the pedals from the Saints to my XTR Trail, it turn out the pins on the Saints made it very hard to unclip
. The large Druid fit my stumpy legged 5'9" body quite well with a nice steep STA. The drivetrain did not have drag that I noticed, but the Minions with Cushcore did. That and it was my 3rd day in a row riding. It was my first time on AXS Eagle and I am not used to it, so shifting wasn't intuitive for me. With my build kit the test would have gone smoother. The drivetrain does make a slight noise, sounds like the lower chain guide. I don't like the moss colour but the bike looks great. The frame had room for my 1 litre water bottle with spare for a frame make or the like. My legs didn't rub anywhere. FBC is located in town here and the shop I work at PT is a dealer. I don't think this biased my opinion???
The good.
1. This bike carries speed in the rough. Like to go fast, you will love this aspect, I did. I think its the rearward axle path that helps here. It felt smooth but without being very plush. Plush enough, especially when you consider it's only got 130mm out back.
2. It is a great climber. I noticed some bob with the shock open on my way to the trailhead. I flipped the climb switch and left it on for most of the logging road climb. I flipped it off for the last bit and it still pedalled well. I would use it on the road, but if it wasn't available I could live with it. The shock's compression was backed off completely. Once on the trail part of the climb it pedalled great, did not wander even with the high bar, the steep STA was perfect for me and, traction was good. I would be very happy with it.
3. Handling was intuitive. Maybe because I'm on similar 29ers but I found the cornering was spot on. Stable and could still be whipped through S turns.
4. The 450mm seat tube gives me plenty of room for a dropper.
5. The frame looks beefy and seemed stiff laterally.
6. Room for a good 2.5 tire.
The bad.
1. I felt some very slight brake jack. My boss said he felt it so I was looking for it. I didn't brake extremely hard, what I felt was minor and, it would not put me off.
2. $4000 Canadian dollars for the frame with no stock build kits available will put some people off.
3. Moss, WTF?
I just got my Fugitive last August so I'm not in the market at this time. If I was this would be a contender. Better than the Fugitive, I wouldn't say that. It has the rearward axle path that is an advantage in some situations. Long term durability is unknown but, the hardware and bearings look promising. The Fugitive will still be ridable when there are only cockroaches left. Lastly, perhaps unique to me, it won't accept a Mudhugger mudguard, something I consider essential here on Vancouver Island. I could probably fabricate some kind of adaptors if push came to shove.
