First ride: Ten miles, maybe 2k climbing, mixed volcanics, sand, tech and flow, a few jumps, some natural features, nice and mixed.
Tech Climbing: The tech section is like trials light, pretty tough to ride without a few dabs or repeats, the first move outta the parking lot is a tight S turn climb on irregular lava flow. I had two repeat this move once, but normally I get that move.
What I figured out quickly is that because the rear wheel moves back, I had to change my approach to climbing over square edged rock.
On my GG bike, when I’d approach rock I’d slow down and press the tire into the rock, then grind over. On the Druid, if I slowed down I’d bog down, because I didn’t the have the tire pressure to push against. Once I figured this out, I just pedaled into and through the rock.
XC climbing on loose: The climbing was pretty good, I didn’t lose traction any more than normal, perhaps traction was better on the Druid because my partner lost traction on his GG bike. In terms of overall ride quality and efficiency, the Druid pedals well, no obvious drag, I only heard chain noise at really low speeds; the noise is from the guide/roller.
Initially I was running 145psi in the Mara Pro, this felt okay but it was out of balance with my coil fork; I also wasn’t using much travel, so I reduced to 135psi which rode more plush and balanced better with the fork.
Downhill flow: the bike is fast, the back end stays on the ground, no hopping or wallowing, carves well, feels very balanced. Going though turns was stable, no issues with traction. At speed the Druid is quite happy to get off the ground.
Downhill tech: this is definitely a strong suit for the Druid, it was fast through the rocky stuff, handled square hits amazingly well, very fast and super composed.
Drops, jumps, and natural airs: so I’m an old guy, I’m not a park rat, and I don’t ride downhill parks. My idea of a good time is rocky tech stuff that makes you work. That said, I’ve never met a rock I didn’t like, so if I see a natural feature I’ll jump it.
The Druid has no issues landing, but it does take some added speed to get into the air cuz it’s just not as poppy as a normal bike. Go fast enough and the Druid performs very well, it’s agile in the air, predictable, and the landings are amazingly composed.
Speaking of composed, there’s this wood feature built out over a steep hill, hit it with speed and you get maybe five to six feet vertical and fifteen to twenty feet horizontal, the landing is steep, and there’s a hard turn at the bottom. Normally I ride this drop and I can feel the landing, on the Druid I didn’t feel anything, it was like spreading cream cheese on hot bread. I did the drop again to make sure it wasn’t the koolaid speaking, same landing experience.
Overall: great bike, wish I’d gotten one sooner. The magic is real.
Pros: absorbs square hits, traction for miles, plush ride, composed when landing drops
Cons: low bb, I hit my pedals more than a few times and that’s running 155mm cranks and flat pedals. Only one water bottle mount. Internal line routing is so yesterday.
Set up: I ride the Druid with the stock DPX2 snd was not disappointed, though the Mara Pro a better shock. The 160mm fork paired well with the Druid, geo felt good, not overly slack, no front end floppiness. I love the high front end!
The damp ride of the Druid pairs well with a good air shock; I’d hesitate to dampen it further with a coil shock. Yeah, yeah, I have coils, my fork is a coil, but this bike is damp enough with air.
Extras: I’m a linkage fork fan, I got a Shout and a Message. The best thing about a linkage fork is the way it handle square hits and the way it maintains traction; tracking ain’t bad neither.
The Druid suspension is the rear end equivalent of a linkage fork, but without the negatives of a linkage fork; no issues with shock absorption and no harsh ride.
My dream bike would be a Druid with a Motion Ride E18+ 29” 160mm fork.
