Hi cdub,
I'm yet another
follower of the bunny-hop path, which proves to be a rocky one...
Not that I do them consistently, nor that I can sustain them for long, but for now I'm finding wheelies easier. However, I do them firmly seated (I'm more stable that way), so I'm in a wrong position to transition to a bunny-hop.
I'm also trying the very first phase, which is leaning back to lift the front wheel and effectively manual for a while. The problem I'm running into is that I either don't pull on the handlebars hard enough, thus the front wheel doesn't get high enough off the ground, or I pull too hard, and have to bail out / jump off the bike.
Finally, I'm working on a back-hop, a stationary and hence easier version of a bunny-hop. I frequently manage to get my bike almost vertical while standing on the pedals, but then fail when I try to lift the rear wheel off the ground -- I just seem unable to make my feet stick to the pedals! I'm pushing against the pedals and keeping my toes bend down, but apparently must be doing something wrong
Any suggestions on how to improve that "mission-critical" aspect of my technique?
Cheers,
-Tomasz
First off, your going to have to learn how to do a wheelie standing up. this will make the other steps fall into place much easier. As far as the old question of how hard to pull up on the handlebars, the only advice i can give is simply practice. Also try leaning your body way back, that way to will not have to pull up as hard.
Fnd now for your big problem, slipping off the pedals. I see that you are already pushing your toes down, which is the most common mistake. so about all i can reccomend is getting new pedals ( any wellgo B- series) or just get out there and practice. maybe dont try as hard to get your bike vertical. you can see from the pics that i am not really that high up in the wheelie and i have speed, which makes everything easier.
while all this info is great i am giving you, it is ultimately up to you to tell yourself " i am going to j-hop no matter what" if you carry this mentallity, you should be decent at it within a day.
