...and a 12-27 setup or close to it... Most of you running this or similar setups along with a chainring combo in the area of 42/32/20, how is this possible? According to my calculations (42-20=22; 27-12=15; 22+15=37) if the short cage has a total capacity of 29T then this setup would be way over. I realize that the total capacity figure from the manufacturer is usually a little conservative but, not by that much. I also understand that you need to account for 'chain growth' that is inherent in most FS bikes. What I mean by that is, as the bike compresses the frame's center from the BB to the center of the axle elongates which effectively reduces your drive train capacity as your chain gets shorter through the compression stroke. Basically, as you ride, your FS is doing its thing and your chain is getting longer and shorter as you bounce along the trail. So, what am I not getting here?
Cheers,
Sean
Cheers,
Sean
