I'm sorry to do this to you num1badz, but I would like to dispute your "How to Clean Your Chain" article->
http://www.bluecollarmtb.com/how_to/clean_chain.htm .
2. Choose a good solvent that will clean and lubricate your chain. It is recommended that you use a citrus solvent with a good lubricant.
Tips:
1. It is best to use a chain cleaning unit rather than removing your chain. Removing your chain causes unnecessary wear and tear and will shorten the life of your chain.
2. Always make sure that the solvent you are using has a good lubricant. A solvent lacking lubricant will dry out the chain.
Now you're telling people to lubricate their chains with a solvent, now a solvent usually evaporates after a short while, which is great when giving the chain a good washing and leaving little residue. Chains need to be lube with a chain-specific lube of some type or at least oil.
In the tips:
"1."indicates that removing the chain causes more wear, cleaning the chain on the bike while ok for clean rides is not as good as a through-soak and scrub down with solvent for dirtier rides. A through clean off the bike will cause less unnecessary wear by having crap in the links for the chain to wear out with.
"2." Using solvent as a lubricant, to make it clear:
solvent aren't lube!. A lubricant without solvent usually means the lube stays put better.
"How to Tru a Wheel" while it gives you some idea on how to true a wheel, it doesn't mention anything about even spoke tension. Uneven spoke tension will mean a much weaker wheel and even more 'so call' truing will over time create a very weak and unstable wheel.
Sorry man, but good website anyway especially for non-addicts unlike moi.
