I'm looking at the 5-Spot.PAINpusher said:So Busta...
Whats your next frame going to be??
Ohh.. That's harsh..hammerheadbikes said:man..
you need to learn how to ride
come on out with us sometime
(just busting your chops!)
hammerheadbikes said:just jacking with ya!
you might want to try a tad taller fork
like a fixed travel nixon with intrinsic damping
I appreciate the suggestion fellas. I've thought of those very things myself. I'm just trying to shell out the least amount possible. If I sell the HH for about what I'm asking I can get more of what I'm after for almost nothing out of pocket. A shorter stem isn't going to be much, so I'll try that.RoundRockTJ said:I think you should run a 140mm fork and a shorter stem. That should help a ton. On my Salty all I did was go with a 10mm shorter stem and that helped my descending a lot. If you like we can go ride rattlesnake and swap bikes. I have an 06 X5. It might be a little small with the 23"TT.
hammerheadbikes said:I honestly don't think going to a 5 spot will give you much, if anything
the frame isn't nearly as stiff for starters
the sizing is different as well
a large is probably too big, a medium isn't going to be any more stable
you haven't said what your issues are, address those first
Must be the best shock in the world then. My DHX-Air simply rocks.The Squeaky Wheel said:DHX-Air...yuck.
If you're going that route then I'd suggest holding out for the new Rock Shox Pearl. I had a chance to play around with one recently and it's a much nicer air shock than the DHX Air.
LOL.RoundRockTJ said:Must be the best shock in the world then.
so is the Pearl gonna come stock on some bikes or at this point only aftermarket? i have actually not heard of it yet so it is cool to hear you beta testing things....The Squeaky Wheel said:LOL.
I certainly wouldn't go that far but my initial impression is that I like it better than the DHX-Air. I'm just not a big fan of the DHX-A. Too on/off for my taste. It's very plush and I can see why people would prefer it to the stock DHX-C which has a somewhat opposite problem of firming up too quickly. But the lack of midstroke support bothers me. The PUSH mods for DHX-C are super and I'm fortunate to have been a beta tester the past few months. Full production kits are at manufacturing and will be ready shortly after New Year's. The result is amazing.
Getting back to air shocks, the Pearl has very consistent damping throughout the stroke range. Plus, it has very large volume and requires much lower pressures than the DHX-A. Plus, plus, there's no fiddling with bottom out, boost valve, etc... Just set the preload and adjust compession & rebound externally.
