I have a question for someone who's familiar with the internals of the headshok cartridge:
I own two ultra 70 forks/w lockout but one has very little damping (to get acceptable damping I'd turn the lockout slightly to close the internal ports). with the cartridge out theres no fluid resistance when moving the shaft like the other. so I took it apart and there seems to be a damaged valve shim. looking at the red piston you see two slotted ports which has a thin shim over it but right at the port areas the shim seems to have sections broken( the shim isn't completing round) allowing you to see right through the ports.therefore theres nothing slowing the oil flow except the port size.
ok. today I took apart my other cartridge, with acceptable damping like my Lefty, and sure enough the shim completely encircles the piston and covers the ports.
so, the big question is how do,can you replace this shim? anyone know what to do??
I really don't need this cartridge because both forks are for winter only use but I should repair it before c-dale completely drops all parts for it, like my Leftly ELO.
any help would be appreciated.
