I have an 03' FXR. I ran it in the 5" mode when I first got it but switched to 5.75 pretty quickly. I think it rides just as well in the long travel setting but you will need a stiffer spring. I needed a 350 lb spring for the 5" setting but use a 400 lb spring for 5.75.67degrees said:I have a Foes FXR and have been running it in the 5" travel setting. Are any of you running yours in the 5.75" - 6" setting? What are your impressions? Is it still as trail worthy in the longer travel setting?
