1 - 3 of 3 Posts
I really need help adding air into a Float R air shock on an NRS3. I cant figure out what to do, and the buyer says that it did NOT come with an air pump...
Can I use a battery-powered inflator? I need to add about a hundred PSI, right now it has 24.
And I need this help really fast...
Niner EMD
due to the low air volume and precision required in filling a shock I would stick to the standard shock pump. You will have to buy one if you dont have one. I've never used anything but a shock pump for my front and rear shocks.
1 - 3 of 3 Posts
