Question for the HH owners. I bought the AVA sleeve from Hammerhead to replace the float R can (mine's an 02 HH). I'm planning to have it PUSH'd but will probably wait till after they relocate. Anyways, I'm just wondering if anyone is running the AVA on the HH and what they set it to. I'm 155lbs and have the dial all the way out (so it's most linear). One thing that I didn't anticipate was that I have to use much more air pressure to get the same amount of sag as when it was just the Float R. I haven't really fiddled with the dial because it runs fine right now (i'm a believer that sometimes keeping it simple is best).
The shock actually feels firmer now than the float, especially in the initial 1/3 of the travel (so small stutter type bumps/rocks/roots). But I still bottom the shock out (that's fine..I expct to with the things I'm doing). I'm thinking that the higher air pressure is the cause of it (dur dur) but because the shock spring is more linear, it's easy(or maybe easier) to bottom the shock. Maybe I should adjust the dial? Put more air pressure? I don't think I want to do that. Really, I'm just curious....I'm gonna have it PUSH'd anyways so these questions won't pertain to my current set up after the modification. Just looking for some feedback, like is this normal? etc. Thanks.
