1 - 2 of 2 Posts
A few...
Risers tend to be wider, so if you need or are more comfortable with a wider bar it may be a factor. Also, there are less Ti options in the riser department if that is your thing. I favor Ti as a handlebar material due to the way it fails when compared to aluminum or carbon. Also, if you plan on mounting lights, risers can be a bit of a pain as it is sometimes hard to get them mounted squarely.
1 - 2 of 2 Posts
