Nater said:
Level Components has a 135mm fixie hub too. BTI lists is as in stock too so your LBS should be able to get it...assuming they have a BTI account.
https://www.bti-usa.com/images/thumbnails/large/ll/ll1233.jpg
This is probably the best setup out there for fixed gear hubs. Unfortunately, the Level product is really a 120mm hub with spacers and an asymetrical cog that allow the chainline to be adjusted for 135mm use (still cooler than all the sapced out Track hubs). I'd rather see Level put out a dedicated 135mm hub and widen the flanges as much as possible. Also, the asymetrical cog prevents you from flipping it for extra cog life.
It's trick but really why would anyone want a hub that converts from 120mm to 135mm and has an adjustable chainline? The difference between road and mountain wheelsets isn't just 120 vs 135mm spacing and 45 vs 52mm chainline... it's rims, spoke gauge, spoke count, hub weight, etc... I can't image anyone has a use for a wheel set that is compatible with their road and mountain bikes. Maybe it's just me, I have different bikes for road/off-road and different wheels for them.
The Level cog interface seems to split the difference between the 6bolt iso and splined mounting systems (such as White Ind). The White Ind is probably the best setup; it's as easy as changing a freewheel cog. The Level method at least makes you only mess with 3 things instead of 6; but 1 is still better. Also, I've never stripped hub threads or sheared brake rotor bolts using fixed cogs. High quality parts installed properly tend to work. That said, if there is a better system I will use it.
The i9/Level prototype looks rad... hope that develops into a true 135mm fixed hub.
