1 - 20 of 40 Posts
I figure this must be a common Ibis issue with their current linkage design. This is on a Ripmo AF with Assegai's which throw rocks constantly. Rocks get into this spot and get pinched by the linkage. I ride in the Sierra's so there's rocks everywhere. Does anyone have a fix for this? I was thinking of using some frame tape to just bridge across the area. I've heard of using a piece of foam but I think foam would just trap dirt and then constantly rub the dirt against the frame, causing damage as well.
My new Ripley has a glued on flap that helps divert some of it, but I plan to tape the surfaces with Racers tape and then use some foam to fill the gap. Did just the foam on my Son's Ripley and it works perfectly.
Both bikes are already scratched up in there, wish I would have done it day one.
Quick easy fix
I solved this problem on the Ripley 4 w/ pipe insulation foam. Once it is in place it never slips out. No Tape! No glue! I have 2.5 months of riding with it in place.
Easy cheap fix!
Ride On!
Good idea to put some protection on the seat tube, used helicopter tape on mine. I pinged Ibis and they sent me a flap/guard that works like a champ on my Ripmo, assuming the same one will work with the Ripley. Ping them about it and they will send you one. Curious that they have not made them available on their store yet:confused:
Discussion Starter · #10 ·
Could you post a picture so we could see? Thanks!
Reach out to Ibis. They have a piece of foam that they are getting custom cut to fit in there. They sent me one a few months back and it's been working great. I also put some helicopter tape on the surfaces before putting the foam in as an added layer of protection.
Pics of the rock flap on my ripley4. Apologies for the poor angle with these quick shots.
Also, on p55 of the most recent ibis owners manual there is an image of the rock flap on the exploded view of the ripley & hardware
I had asked ibis about the custom cut motofoam pieces that others had mentioend & the ibis rep said they were now sending out the rock flap instead of the foam.
Just curious, did you call or email ibis support? I emailed them this morning asking, even mentioned the flap/guard and the response was that that they don't make something that will work on my bike (ripmo af). And that was the end of it, no option of foam or flap. Maybe they're not offering it anymore?
I wonder if it is because your bike is an AF. Maybe they only provide it for the carbon bikes. Just like the downtube protector is only on the carbon Ripmo.
That's a great point, I think you're probably right.
I have the same chip that sfr4dr has but on the right-side of the linkage mount, with aluminum I'm guessing there's really no worry of structural problems for those kind of dings.
Discussion Starter · #17 ·
Yeah, no structural worry yet on mine but crunching rocks in there over and over isn't good for anything including the stress transferred to the bearings. A small plastic fender hanging off the seat tube and not touching any moving parts would be best. Like one mentioned, a piece of foam will trap sand particles and rub the alloy down over time. Protective tape under the foam would work though. The new Santa Cruz bikes have a little flap over the bottom of the shock. I might make something like that or the one above on the Ripley and adhere it with 3m double sided tape. It sure would be easier if it already came with it though!
Totally agree! It's a pain to have to solve for this, esp. when the og ripmo has had a similar issue, ibis is hopefully working on a guard or something.
Decided to clean the linkage up and have a better look and a decent part of the bottom edge of the linkage mount has been chewed up. I've had the bike for about a month, glad I saw this was an issue on here, or it'd be awhile before I noticed.
I'm trying a fender and see if that helps, might tape up the linkage too like other people have done.
They have only been making bikes for 38 years......Just give them a little time to figure things out.
I am sure they are working on it!!
Discussion Starter · #20 ·
That fender does look like it will take care of most of the issue.
1 - 20 of 40 Posts
